1992 GMC Pickup Coolant Near Carb
1992 GMC
JETSFAN
my gmc pick up has water coming from the back of the carb.does this sound like a cracked block to you?
Apr 13, 2007 at 1:30 PM
MICKEY-D
  • 304 POSTS
There shouldn't be any water near the carb. Do you mean maybe the back of the intake manifold?? Sometimes the intake gaskets can leak coolant, they are the end ports on the manifold.
Jan 7, 2010 at 3:09 PM
Suggested Repair
Confirm whether the coolant is actually coming from the rear of the intake manifold rather than the carburetor. Inspect the intake manifold end-port gaskets, which can leak coolant, and replace them if leaking.
Conversation Summary
The owner of a 1992 GMC pickup reported water coming from the back of the carburetor and asked whether that indicated a cracked block. The expert said coolant should not be near the carburetor and suggested the leak may be at the rear of the intake manifold, where end-port intake gaskets can leak coolant.
