1991 Other GMC Models cant get clutch to work.
1991 GMC
24,000 MILES • 4 CYL • 2WD • MANUAL
SLIDEKING 54
Lost clutch @ stop sign. Resevoir was low. Filling it didnt help. I assumed failed master or slave. Had a long drive coming up, so I replaced both. Bled both of them every way I could think of, although I havent been able to get ahold of a power bleeder. I seem to have excessive free play, (more than when it worked) No pressure till pedal is halfway down. Watching through the inspection hole, I measure a 1/2" of travel on the slave rod. Should this be enough to disengage the clutch?
Mar 30, 2010 at 5:43 PM
HMAC300
  • 48,601 POSTS
you'll have to check to see if the release arm has bent or the release bearing has gone through the pressure plate. If you are getting 1/2" of travel that should be enough. Cehck the release arm especially if it is a stamped piece.
Apr 2, 2010 at 8:21 AM
