1986 Other GMC Models heater
1986 GMC
BOLEXI
Heater problem
1986 Other GMC Models 4 cyl Two Wheel Drive 128,00 miles
I have a gmc diesel 40 box truk (ISUZU) and the heater will not get hot, gets luke warm. I had checked the temp of the radiator fluid with a thermometer and after 7 miles of driving and then idling for 20 minutes the water was only 140 degrees. I also have over half the radiator covered with cardboard I opend the thermostat housing and tested that water and it was only 140 degrees also.. I then replaced the thermostat and still the same problem.
Dec 15, 2007 at 6:57 AM
  • 31,937 POSTS
Hi there,
You may have a blocked heater core or a faulty heater tap that is not opening fully, check the flow through the heater core and the operation of the tap controller and the heater tap.
Mark (MHPAUTOS)
Dec 15, 2007 at 9:08 PM
