1986 Other GMC Models bouncing spedo
1986 GMC
REDNECK1969
Drive Train Axles Bearings problem
1986 Other GMC Models V8 Four Wheel Drive Automatic
what would cause the speedo in my truck to bounce while driving
Apr 1, 2010 at 3:24 PM
HMAC300
  • 48,601 POSTS
the cable is either hanging up in the sleeve or it needs to be lubed. If you are going to lube it use thin grease like lithium and take it apart form the top and pull the cableout that way. If you don't have the cable type then your speedo can be screwing up or you speed sensor is , but you may have a service engine light on.
Apr 2, 2010 at 8:14 AM
