1986 Other GMC Models 454 motothome stalls
1986 GMC
65,000 MILES • V8 • 2WD • AUTOMATIC
DHARRIS
Lookig for help on a stalling issue. The initial problem was the RV would only run at 35 miles per hour or less or it would stall out. I replaced the componets of the HEI distributor and that seemed to help a lot. Now the RV will get up to 75 but on occasion will do the stall thing. If I remove my foot off the accelerator and then press gently increasing the pressure the engine will resume and continue to run until the next time. Any thoughts on how to proceed
thanks
Feb 20, 2010 at 1:16 PM
HMAC300
  • 48,601 POSTS
your accelerator pump on your carb is probably shot plus you have a vacuumleak more than likely. You'll probably need the carb rebuilt. change the fuel filters as well and make sure you have afilter in front of the fuel pump. If you have TBI which i dont think you do, then the injectors may be clogging or the wires going to the top are not making good connection.
Aug 4, 2010 at 6:27 PM
