Your accelerator pump on your carb is probably shot plus you have a vacuumleak more than likely. You'll probably need the carb rebuilt. Change the fuel filters as well and make sure you have afilter in front of the fuel pump. If you have TBI which I dont think you do, then the injectors may be clogging or the wires going to the top are not making good connection.
SPONSORED LINKS
Thursday, August 5th, 2010 AT 1:27 AM
