1984 Other GMC Models fuses
1984 GMC
190,000 MILES • V8 • 2WD • AUTOMATIC
JDO
i have an issue with fuses blowing for the instrument panel . i have another panel coming but i need to know where or what all the fuses are for im the fuse block. most of the writing on it ,is unreadable. where can i get picture of the block so i'll know what the fuses are for
Nov 29, 2008 at 9:03 AM
HMAC300
  • 48,601 POSTS
if you still have an owners manual or know someone that does it should show what the fuses are for. If you are blowing an instrument panel fuse look for a switch that was installed and screws going into one of the wires. That is the most common cause of ip fuses blowing. Or someone has gone into the dash to connect a radio and hooked it up to the wrong place.
Feb 16, 2010 at 11:19 AM
