1979 Other GMC Models
1979 GMC
DAN C
Electrical problem
1979 Other GMC Models 4 cyl
Why is a resistor needed or not needed on an ignition system?
Nov 12, 2008 at 8:46 AM
HMAC300
  • 48,601 POSTS
if you have a points type system and some electronic ignitions if you don't have a resistor to cut the voltage down from 12 down to about 9 it will burn the points right up and damage some of the electronics in the electronic system. Not all electronic systems need resistors though.
Oct 10, 2009 at 2:26 AM
