1989 GMC Jimmy No-Start in Rain
DOGALOO
I have a 1989 gmc jimmy s-15 4x4 with a 2.8 v-6 5- speed std. It has 170,448 miles. On rainy days the check engine light comes on for a little while. I was driving in the rain and when I turned it off and then tried to re-start it it would not start. I was getting a weak spark so I replaced the coil but it still would not start. The next day it started right up and ran fine. But it would not start after I turned it off. I pulled a few plugs and it wasn't flooded. I have spark and fuel but no start. Also, my starter does not always kick on when I turn the key now. I was able to use a screwdriver on the solenoid to turn it over but now that doesn't work. It has never done any of this before. Could this be caused by a bad battery? If not what could it be?
Aug 17, 2007 at 8:48 AM
  • 75,988 POSTS
[quote:49c2df3934="dogaloo"]I have a 1989 gmc jimmy s-15 4x4 with a 2.8 v-6 5- speed std. It has 170,448 miles. On rainy days the check engine light comes on for a little while. I was driving in the rain and when I turned it off and then tried to re-start it it would not start. I was getting a weak spark so I replaced the coil but it still would not start. The next day it started right up and ran fine. But it would not start after I turned it off. I pulled a few plugs and it wasn't flooded. I have spark and fuel but no start. Also, my starter does not always kick on when I turn the key now. I was able to use a screwdriver on the solenoid to turn it over but now that doesn't work. It has never done any of this before. Could this be caused by a bad battery? If not what could it be?[/quote:49c2df3934]
Jump A to B on the diagnostic connector or use a code reader find out what code/s it is.
Meanwhile, get the battery load tested-make sure its clean-up with tight connections and retry. Then you can comeback for more.
Aug 17, 2007 at 9:46 AM
Suggested Repair
Retrieve diagnostic trouble codes by jumping terminals A to B on the diagnostic connector or using a code reader. Load-test the battery, clean and tighten the battery connections, then retest starting.
Conversation Summary
A 1989 GMC Jimmy S-15 with a 2.8 V6 intermittently shows a check engine light in rain, then fails to restart despite spark and fuel. The starter also engages inconsistently, and jumping the solenoid no longer works. The owner replaced the coil and asked whether the battery could be at fault. The expert advised pulling codes and load-testing the battery with clean, tight connections before further diagnosis.
