Shuttering Jimmy
SUMMER
  • 13 POSTS
I took my 1990 GMC Jimmy 8000 Ft above sea level. It really did nto like that. Now it shutters constantly and smells of gas. Sometimes it seems that it is not taking in the gas well. Did i mess up my fuel pump? :cry:
Jan 12, 2006 at 8:28 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the fuel odor and poor running inspected before further parts replacement. Stop operation and arrange assistance if a fuel leak or strong raw-fuel odor is present.
Guidance references and applicability
Source: Original question and visible replies. Owner outcomes are attributed; other participants' experiences are not treated as this owner's repair. Next steps are editorial guidance, not a confirmed diagnosis.
Read the replies · Discussion summary and reported outcome
2CARPRO JACK
  • 11,533 POSTS
maybe some bad gas
Jan 12, 2006 at 9:41 AM
HEARTS88
Check your EGR valve. If I remember correctly, you will have an Electronic EGR. Not cheap to replace, have a mechanic check it out.
Regards.
Hearts88
Jan 12, 2006 at 10:27 AM
HEARTS88
On second thought... That year may not have the Electronic EGR. But check...if you do, it could be that. I had a'93 that was shuttering and stuff. Would sound like it was bogging out.
Had to replace the Electronic EGR Valve.
Regards.
Hearts88
Jan 12, 2006 at 10:29 AM
SUMMER
  • 13 POSTS
Thank you i will look into that.... :)
Jan 13, 2006 at 3:27 AM
SUMMER
  • 13 POSTS
BAD GAS THO??? I have refueled serveral times.....another thing i just noticed tho is, my tail pipe is coverd in black. only on the inside.
Jan 13, 2006 at 3:48 AM
HEARTS88
Summer,
Black on your tailpipe... hmm... does it come off like soot?
Could be carbon... Did you check into the EGR valve.
I know when I had my truck, and removed the Electronic EGR valve it was covered in soot like crud. my tail pipe was the same way.
Let me know how you make out.
Hearts88
Jan 14, 2006 at 1:32 PM
Discussion summary
Shuttering Jimmy
A 1990 Jimmy developed persistent shuddering and a gasoline smell after a high-altitude trip. The owner later reported black deposits inside the tailpipe and said several refuellings had not resolved the concern.
Reported outcome: No confirmed diagnosis or repair was reported.
Bad fuel and an EGR fault were suggestions, not findings. The installed EGR type was uncertain, and tailpipe deposits alone did not establish a cause.
Read the original discussion
