1999 GMC Jimmy AC Compressor Not Coming On
SAPPER35
1999 GMC Jimmy 4.6L 4WD 133,000 miles
I recemtly recharged the system and had cold air for about two days now it is all hot air and my compressor is not coming on could I have had a leak and the recharge with leak stop all come out and maybe the system needs a new charge? or am I going to need a new compressor?
Jul 8, 2007 at 7:03 PM
BOOTDOG
  • 665 POSTS
sounds to me you have a pretty excessive leak. a lot of shops can put dye in the system to make finding leaks a lot easier. if ac is important to you then i would go that route.
Jul 9, 2007 at 2:14 AM
Suggested Repair
Have a shop add UV dye and locate the excessive refrigerant leak before recharging the system or replacing the compressor.
Conversation Summary
The owner recharged the 1999 GMC Jimmy air conditioning and had cold air for about two days, then only hot air with the compressor not engaging. They asked whether a leak emptied the charge or a new compressor is needed. The expert said the leak sounds excessive and recommended dye testing at a shop to find it.
