1995 GMC Jimmy Compressor Bypass
KEV1122
1995 GMC Jimmy, 130,000 miles, 4.3L V6
My compressor has a bad bearing w/ a loud, whining noise. I don't want to pay to fix, so I want to bypass the compressor. I need a new belt anyways. Can I bypass the compressor w/ a belt made for that engine w/o air? If so, what is the wheel just below the compressor? The belt routing seems that it would turn that wheel opposite of it's current rotation. Or, do I need a compressor bypass pulley?
Thanks!
May 19, 2007 at 6:41 AM
SERVICE WRITER
  • 9,123 POSTS
You need to make a schetch of the belt layout with arrows pointing as to the rotation. Using a string, wrap it around the pullies so that the compressor is by-passed. IF there is no straight line between the pullies because of compresor interference, you need to remove the compressor and or compressor clutch or not do it.
https://images.2carpros.com/forum/automotive_pictures/30961_wac_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_woac_1.jpg
It looks like the diagram with out a/c has an added idler pulley. You may need to get a bracket from the scrap yard to convert it.
May 24, 2007 at 10:06 PM
Suggested Repair
Sketch the belt layout and rotation, then trial-fit a string around the remaining pulleys to bypass the compressor. If the compressor blocks a straight belt path, remove the compressor and/or clutch or do not bypass it. A non-A/C layout uses an added idler pulley, so a scrap-yard bracket may be needed.
Conversation Summary
The owner of a 1995 GMC Jimmy wants to bypass a noisy A/C compressor with a bad bearing instead of repairing it, and asks whether a non-A/C belt or bypass pulley will work. The expert advises mapping pulley rotation and testing a string path that skips the compressor. If the compressor interferes, it or the clutch must be removed; a non-A/C setup uses an extra idler and may need a scrap-yard bracket.
