Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Jimmy
Trouble Codes
P Codes (Powertrain)
P0100 - P0199
P0174
code 1997 gmc jimmy 4wd
1997 GMC JIMMY
ESPBRAD
MEMBER
what does p0171 and p0174 mean what part is it?
Nov 28, 2007 at 11:33 AM
BMRFIXIT
Experienced Mechanic
The codes P0171 and P0174 both indicate that the engine's air-fuel mixture is running too lean. Here is a guide to help you fix it but I can tell you a clogged fuel filter, vacuum leak or a bad MAF sensor can cause this problem.
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Here is the locations for the MAF sensor and fuel filter. Check out the images (below). Please let us know what happens.
Images (Click to enlarge)
Nov 28, 2007 at 11:42 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
