Engine tapping sound and the engine exhaust does not sound right
CJLOTTI
  • 5 POSTS
1999 GMC Jimmy 6 cylinder 4WD. When i start engine after it sits for many hours or a day or two there is a tapping sound and the engine exhaust doesn't sound right. after running a minute or two the tapping goes away and all sounds good and runs good. tripping and concerned!
CJ
Nov 4, 2007 at 8:10 AM
CHEVY22
  • 1,375 POSTS
sounds like your lifters may be collapsing. this is very normal on the 4.3. the job requires about 6-7 hours and about $800.00 at a shop.
Nov 4, 2007 at 9:46 AM
CJLOTTI
  • 5 POSTS
wow, thanks for reply..
okay, so why is a lifter collapsing? what causes it and why is it happening??
only making noise on start up. once running for a minute or 2 it goes away.
do i have an oil pump problem?
or a vacuum leak issue? how bout cooling system problem?
Nov 4, 2007 at 2:34 PM
CHEVY22
  • 1,375 POSTS
a lifter will collapse over time from simple wear and tear. they lose pressure and when this happens you will get a noise on start up and eventually all of the time. when this first occurs they will pump back up after a few moments . you should check for coolant leaks or coolant in the oil but most of the time its just the lifters. i have done more than my fair share.
Jim
Nov 4, 2007 at 10:31 PM
