97 Jimmy brake lights
1997 GMC JIMMY
GIGI2476
1997 GMC Jimmy, 103,000mi, V6
Brake lights do not work (except for 3rd one)
checked all fuses, replaced bulbs, replaced brake light switch...still not working. Now what?
Oct 17, 2007 at 1:53 PM
Check the trailer connector wiring could be shorting out.
Oct 18, 2007 at 5:31 PM
KING_HILLBILLY
The hazard switch in the steering column is going bad if your 3rd light is coming on and the other lights are not. Having the switch replaced will fix this problem. I have a 97 gmc jimmy which had this problem.
Jul 13, 2010 at 12:55 PM
