2002 GMC Jimmy water leak
2002 GMC JIMMY
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
TUCOBEAR
I am not sure if the caegory is right but I put air conditioner. When I shut off my air conditioning switch to off it makes a strange noise and it is continuous as long as the vehicle is running. Then the other day after a 150 km trip on the highway, once I parked the vehicle in the garage I noticed that there was a water leak under the passenger side of the jimmy, it was not wet anywhere inside the vehicle. Does anyone know what this problem might be? Thank you.
Jul 15, 2008 at 2:23 AM
MERLIN2021
  • 17,250 POSTS
Not sure about the noise, but the water, if it is just water, is normal! It comes from the evaperator core drain.
Jul 15, 2008 at 2:29 AM
