2002 GMC Jimmy P0141
60,000 MILES • 6 CYL • 4WD • AUTOMATIC
JASONGUAY
Hey guy's
I have replaced my o2 sensor in all banks and I still get a p0141 code. I am not sure where to go from here. I sprayed all contections with contact cleaner to ensure they are making contact, probed for voltage and still that nasty p0141. I checked out my Haynes book and no options? For a diagnostic what should I do now?
Thanks a lot
Jason
Nov 21, 2008 at 11:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Have you reset the engine light after these attempts? If not, you may need to do so and see if the light comes back on again.
Nov 22, 2008 at 2:29 AM
JASONGUAY
Hey guys;
Thanks for the response. I have reset the computer, installed a new sensor and have check the 20amp fuse that is adjanctant to sensor. Still no luck and again that pesty p0141. I have spoke to a friend and he thinks it could be an injector but wouldn't that fault another code?
Thanks a bunch
Jason
Nov 23, 2008 at 6:15 AM
ONEI3RD
  • 5 POSTS
when you cleared the code how long did it take to come back on
Dec 11, 2008 at 9:57 AM
JASONGUAY
Hey thanks for the response.
Well, I clear the code each time and within 50 to 60 miles that darn check engine light comes up again. I replace all O2 sensors and still I get a p0141.
Thanks
Jason
Dec 11, 2008 at 12:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
I don't believe this is an issue with the injectors.. P0141 is heated oxygen sensor circuit malfunction You stated you arleady checked the supply voltages to the sensor? If not, do the following.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_33.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_10.jpg
Dec 11, 2008 at 12:16 PM
