2001 GMC Jimmy when
2001 GMC JIMMY
105,000 MILES • 6 CYL • 4WD • AUTOMATIC
AARON47933
when you turn the heaer on it doesn't warm up, i have to drive it for a little while then the gauge light comes on, it goes back to normal setting on the gauges then the heater will work, i believe it's the thermostate and if so how do i go about replacing it myself
Dec 1, 2008 at 5:09 AM
DOCFIXIT
  • 18,828 POSTS
Drain antifreez follow top radiator hose to engine and thermostat is in that housing. Unbolt clean gasket replace and fill.
Dec 1, 2008 at 7:32 AM
