Any ideas as to why my low fuel light is on and i am unable to put more than a gallon of gas in my car with out it overflowing?
Thank you
Mar 31, 2008 at 10:28 AM
SERVICE WRITER
✓Experienced Mechanic
As far as the kick back, that sounds like a plugged vent tube. The fuel is not getting any venting to allow the air to escape as the fuel goes in. When the pressure builds up it spits it back out. Low fuel light sounds like a separate issue unless the fuel is low.
Mar 31, 2008 at 10:51 AM
KRYSTAL04254
MEMBER
how do i unplug the vent tube? is that something that a GMC mechanic needs to do or is it an easy fix?
Mar 31, 2008 at 11:26 AM
SERVICE WRITER
HArd to say without being in front of it. Sometimes, you have to pull the filler neck and vent out to get at it, sometimes you have to drop the tank.
IF there was anything done, such as a fuel pump recently, the vent may have gotten kinked.
Mar 31, 2008 at 11:31 AM
KRYSTAL04254
MEMBER
i recently had major brake repairs but that is it.. what would cause this vent to be plugged?
thank you
Mar 31, 2008 at 11:43 AM
SERVICE WRITER
No, I really wouldn't expect any relationship there.
