2001 GMC Jimmy TRANSMISSION FLUID LEAKING NEAR FRONT OF ENG
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
IRIDERSV
I seem to be leaking transmission fluid towards the front passenger side of my engine area. Is there a hose or something in that area that is causing the leakage of transmission fluid?
Would this be an easy repair for a VERY novice skill level. I only do oil changes etc. myself now.
Jan 14, 2008 at 11:25 PM
MERLIN2021
  • 17,250 POSTS
Two steel lines run from the trannt to the tranny cooler in the front of the truck, it may be a loose fitting, which would just be a tighten it up...or it may have worn a hole thru a line, a bit more involved.
Jan 14, 2008 at 11:59 PM
