2001 GMC Jimmy Serpentine Belt
2001 GMC JIMMY
118,000 MILES • 6 CYL • 4WD • AUTOMATIC
JACK SCHOLZ
I have replaced the serpentine belt and it keeps squeeking. I am not sure that all the parts are there. How do I solve the problem and how can I find an illustration of what parts are involved and the correct procedure to repair it?
Dec 17, 2008 at 3:17 PM
SWILLIAMS
  • CAR REPAIR CONTRIBUTOR
  • 597 POSTS
As much as I hate to say it you may still have all the parts and the belt will still squeal. What you need to do is check the tensioner, put a ratchet in the 3/8 hole and apply more tension. If the squeal stops replace the tensioner. If the added tension doesn't help check all the pulleys and make sure the belt is actually setting down in them properly.
Jan 3, 2009 at 5:01 PM
