2001 GMC Jimmy no heat from the heater
2001 GMC JIMMY
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEITHB
No cooled air or heated air. The fan works at all speeds. The switch that sends the air to different locations works fine. I believe I checked all the fuses and they are OK.
Dec 28, 2007 at 12:55 PM
BMRFIXIT
  • 19,053 POSTS
[quote="keithb"]Heater problem
2001 GMC Jimmy 6 cyl Two Wheel Drive Automatic 97000 miles
No cooled air or heated air. The fan works at all speeds. The switch that sends the air to different locations works fine. I believe I checked all the fuses and they are OK.[/quote
did any one replace the blower moter
check the wiring it may be wired backwords
the fan will spin but no air out
also check if the air way door close
check if the fan connected onto the motor and its not spinning free
good luck
Dec 28, 2007 at 2:47 PM
