2001 GMC Jimmy High oil pressure
92,000 MILES • 6 CYL • 4WD • AUTOMATIC
JWALSH3124
2001 GMC JIMMY 4.3l
My jimmy has high oil pressure which in return keeps blowing the seal on the oil filter I figured it was a clog so I used engine flush and while doing the flush it brought the pressure back down to 40psi so I then drained and filled it with oil and new filter and same thing happened I have repeated this procedure 3 time and it still is blowing the seal. I also have removed and flushed all oil line up to the block any Ideas on what is going on?
Mar 28, 2010 at 2:35 AM
LEGITIMATE007
  • 5,121 POSTS
try changing the pcv valve and let me know what happens, because the pcv valve is the only way to vent the crankcase, so if it is plugged , guess what? I think you know, so try that and get back to me . thanx
Mar 28, 2010 at 4:16 AM
JWALSH3124
[quote:066f5efc11="legitimate007"]try changing the pcv valve and let me know what happens, because the pcv valve is the only way to vent the crankcase, so if it is plugged , guess what? I think you know, so try that and get back to me . thanx[/quote:066f5efc11]
I did that and still no change
Apr 1, 2010 at 9:40 PM
LEGITIMATE007
  • 5,121 POSTS
then this looks like a oil pump problem,
Apr 2, 2010 at 2:27 AM
JWALSH3124
[quote:31c0841b8b="legitimate007"]then this looks like a oil pump problem,[/quote:31c0841b8b]
It was a clogged oil channel right as it re enters the block
Apr 4, 2010 at 7:41 PM
LEGITIMATE007
  • 5,121 POSTS
awesome ,so the vehicle is fixed?
Apr 5, 2010 at 1:32 AM
