2001 GMC Jimmy Engine won't turn off with key
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
POPPYD1953
GMC Jimmy continues to run after ignition is turned off.
Lights come on by themselves intermittantly. rear hatch opens as if by phantom and radio starts playing ,( "if radio switch is left on and volume up").
Key is turned off and out of ignition.
Is there a master relay that can be pulling in or shorted causing this?
Any Ideas?
Mar 4, 2009 at 11:11 AM
  • 75,988 POSTS
Your throttle plate might not be fully closing or your ignition switch is shorting out
Mar 4, 2009 at 8:35 PM
