2001 GMC Jimmy Door hinges
142,000 MILES • 6 CYL • 4WD • AUTOMATIC
GARY CANDRL
I am replaceing the door hinge pins and bushings and am having trouble re-installing the springs on the doors. Do I need a spring compressor to do this? I have spent a lot of time tring to re-install them with no good results. I removed them with a large screw driver and the pin/bushing replacement was pretty simple. The springs are a nother story!
Nov 15, 2009 at 9:18 AM
SWILLIAMS
  • 597 POSTS
Welcome to spring HE^^. Yes you do need the spring tool. It makes it MUCH easier. You can rent them cheap from some parts stores, OR if there is a Harbor Freight nearby they sell one for about 10 bucks. It is actually made as well as the ones sold in other places. If you buy it make sure you put a dab of grease on the adjustment bolt/nut.
Dec 4, 2009 at 4:03 PM
