2001 GMC Jimmy clutch switch replacement
100,000 MILES • 6 CYL • 2WD • MANUAL
JAMES MCGINNIS
Where is the clutch switch located, and how do you replace it?
Aug 18, 2009 at 3:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the clutch pedal position switch is located on the clutch pedal support bracket. just disconnect the electrical connector and unbolt switch to replace.
Aug 18, 2009 at 5:01 AM
