2001 GMC Jimmy brake lights on dash
RESET
Brakes problem
2001 GMC Jimmy 6 cyl Two Wheel Drive Automatic 55k miles
My 2001 Jimmy's red and amber brake light and abs come on after starting engine 2nd time and will usually come on rest of day and stay on. Only after letting it sit for usually overnight will it start without the lights on dash but second start of day they come on again. Tried checking for loose electrical connections on abs pump and abs computer ok. Perhaps wheel sensors? If so how are they checked out and or replaced?
Thanks
Oct 28, 2008 at 8:38 AM
SWILLIAMS
  • 597 POSTS
If the lights come on then a code is being stored. You need to have the trouble codes pulled and see what they show. There are a LOT of things that can cause them to come on.
Oct 30, 2008 at 3:53 AM
