2001 GMC Jimmy
137,300 MILES • 6 CYL • 4WD • AUTOMATIC
GMCKEV
when the car is at an idle the thermostat runs up and the heater blows cold air when i am driving and the engine is running at 1500 rpm or over the heater workd fine and the thermostat operates at around 190 degrees and properly
Mar 5, 2010 at 1:40 AM
JDL
  • 16,098 POSTS
Hi, as far as the heater, less flow through the heater core at idle. It's a heat exchanger, more flow, more heat exchanged. In my opinion.
Mar 5, 2010 at 1:59 AM
