2000 GMC Jimmy trouble starting
2000 GMC JIMMY
11,200 MILES • 6 CYL • 2WD • AUTOMATIC
NCOUSIN
My 2000 GMC Jimmy is having starting problems and its not the battery. It turns over and wants to start, but it just wont. I was driving to work and it was just fine when it suddenly seemed as if the gas peddle didn't matter. no matter how much I pushed it, the RPM didn't follow suit. when I wen to pull over, it suddenly died on me! then it wouldn't start. so I poured some gas into the intake and it started but immediately died again. after that it wouldn't start no matter what I did. so I had it towed home and got a ride to work. 10 hours later I come home and I check the battery. its fine so I figure I can try to start it up. it started but again immediately died. when it did start, a ton of white smoke came out right before it died. I'm completely lost. what is wrong and how can I fix it?
Apr 8, 2010 at 7:22 AM
Check the oil dipstick for gas-If any remove the upper plenum and investigate the spider assembly-its leaking
Apr 8, 2010 at 7:38 AM
