2000 GMC Jimmy transmission slipping after fluid change
BLUECOLLIE1208
2000 GMC Jimmy 6 cyl Four Wheel Drive Automatic
we changed the transmission filter and fluid in our 2000 jimmy now it slips when you first start out from a stop. Can't figure out why. After you get going it is ok.
May 23, 2010 at 6:24 AM
HMAC300
  • 48,601 POSTS
when the fluid was changed the filter may have slipped out of position so it's not getting oi like it's supposed to until you take off. If you continue like this you'll dmage the clutch pack and end up getting a trans rebuild...
May 23, 2010 at 11:57 AM
