2000 GMC Jimmy Transmission Leaks
140,350 MILES • 6 CYL • 4WD • AUTOMATIC
RENE202005
I recently drove my truck without know it was leaking the transmission fluid last night i noticed the transmission wasn't shifting properly and it to time to actually run i was on the street and was closer to an autozone than home so i drove to an autozone and used up 3 quartz of trans fluid and noticed it leaked all of it i heard some kind of noise like a hose or something making some kind of pressure sound and when i shift to reverse it makes a hard sound what could it be?
Mar 4, 2008 at 12:54 AM
PEAR69
  • 1,482 POSTS
Look underneith the jimmy at the transmission. Where is the leak coming from? Sounds like a blown front seal. Were you doing brake stands or burnouts? Where ever the leak is, in order to leak 3 quarts out it has to be undriveable. Have it towed to a repair shop or repair it where it is parked. What ever you do--do not run the engine until this problem is fixed. If you do (or did for over 2 minutes or so) you mine-as-well replace the transmission or have it rebuilt. A tranny with 140000 miles on it cannot take the punishment that 3 quarts low dishes out.  All the sounds you hear are the clutch bands and shifting solonoids crying- starving-for fluid. By the time you hear this it is usually too late.
Mar 4, 2008 at 1:25 AM
RENE202005
Yes i did run it for over 2 mins you think i'll be spending alot of money to fix this up it just happened last night you think its fixable or might as well buy a new vehicle so u think that i burned the transmission. and fudged it up thanx again
Mar 4, 2008 at 4:21 AM
PEAR69
  • 1,482 POSTS
Sorry about the delay in responding--
You can get a new factory rebuilt transmission with a factory warranty for a lot less than a new vehicle. You can also have your transmission rebuilt, which is be cheaper than a factory rebuilt. I suggest having your transmission rebuilt by a good transmission shop like cottman transmission. Sometimes a rebuilt, or factory rebuilt transmission is better than the origional; because as your type of trans. evolves, GM finds weak spots and makes emprovements and upgrades that rebuilders know about.
My opinion is that if you like the blazer then I would get the trans. rebuilt. I would not just get it fixed, get it totaly rebuilt...
Mar 6, 2008 at 2:56 PM
RENE202005
well thanx for the advise it wasn't the transmission it was just a hose that was leaking the transmission is fine thank GOD anyways thanks for all the advise
Mar 10, 2008 at 6:37 AM
