2000 GMC Jimmy Steering Wheel shaing
2000 GMC JIMMY
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOUBLEDGMC
I have a 2000 GMC Jimmy and my steering wheel has recently started to shake while driving. It doesn't make my car move with the wheel, but it concerns me. Also my alignment is off, and pulls to the right. I figure I can fix that with simply getting the car realigned, but the steering wheel has me confused. I know I need new tires and am getting them next week. Would the tires be the problem or am I looking at a bigger issue. Also, when I turn the wheel all the way to one side it makes a crank noise, it's done this pretty much since I got it four years ago so that's not a major concern of mine, but it may help with figuring out the problem.
Sep 14, 2008 at 1:47 PM
BLACKOP555
  • 10,386 POSTS
chances are the vibration is due to the worn out tires and misalignment causing the tires to wear improperly..
replace tires and get a 4 wheel alignment and all should be well.
Sep 14, 2008 at 2:25 PM
