2000 GMC Jimmy right front door ajar switch
CANNON302
  • 6 POSTS
Electrical problem
2000 GMC Jimmy 6 cyl Four Wheel Drive Automatic
removed the dash to replace the heater core.upon re-installation of the dash could not find right front door ajar switch connector behind glove box.searched alldata and mitchell 1 diy.mitchell 1 diy wiring schematic doesn't show actual door ajar switch,but a switch in the door attached to door handle.i want to know if i am crazy or if an actual connector exists for the r.f. door ajar switch in the side of the dash-and if so the connector location, description etc.i have re-removed the dashboard thinking it was caught up inside,but cannot find it anywhere.thanks ted.
Sep 17, 2009 at 8:04 AM
RACEFAN966
  • 5,029 POSTS
OK the drivers side door ajar switch is on the dash at the door opening. The rest of the switches in the doors according to Mitchelle 1. Hope this helps
Sep 18, 2009 at 2:38 AM
CANNON302
  • 6 POSTS
Not sure you understand my question.I know the r.f. door ajar switch is in the side of the dash.I am looking for the connector that connects to it.The connector location,description and where it comes from on what part of the harness or splice etc.I cannot find the connector anywhere on the harness even with the dash removed.Thanks for your time.
Sep 18, 2009 at 2:34 PM
RACEFAN966
  • 5,029 POSTS
Ok from what I can find LF door (drivers side) is on the side of the dash and all others are in the doors is what I am seeing according to Mitchelle 1. If this don't seem correct then I need to have the production date that is on the drivers door sticker.
Sep 19, 2009 at 2:32 AM
