2000 GMC Jimmy PLEASE HELP
210,000 MILES • 4 CYL • 4WD • AUTOMATIC
SWEETPEA20
Hi my 2001 GMC JIMMY is shaking and wobbling and wont let me accelerate over 40 miles sometime,6 months ago I replaced the fuel pump and fuel filter dont know what could be the problem,car ran hot last month so I had the water pump replaced car stop running hot. Now I smell this weird smell when driving smells like some sort of battery or wires burning,when I press the gas peddle I hear a air sound or some sort of wind gushing sound it jerks and shakes and sometimes I hear a rattle, I am scared because this is my only source of transportation dont know what the problem could be please help.
Jul 26, 2010 at 1:09 PM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 26, 2010 at 3:57 PM
