2000 GMC Jimmy noise when speeding up
2000 GMC JIMMY
97,000 MILES • 6 CYL • 2WD • MANUAL
WRW
Whenever I am speeding up there is a loud high pitched noise that doesn't stop until I let off the gas...it also sometimes does this while i have the cruise set. What will make it do this?
Also sometimes when I am speeding up really fast (like when passing) there is a knocking like noise coming from the engine. What could this be?
Oct 25, 2008 at 3:38 PM
SWILLIAMS
  • 597 POSTS
Is the noise a whistle? Could be an air leak in the intake plumbing. Or a vacuum leak.
Nov 9, 2008 at 2:37 AM
WRW
Yes it is like a whistling noise...I also didnt mention that i have an airaid cold air intake...will this be where the problem is coming from? if so how do i fix it or does it have to be professionaly done?
Nov 9, 2008 at 8:58 AM
SWILLIAMS
  • 597 POSTS
Yep that could be the problem. Since most of them make you think they are adding power by creating a bunch of extra air noise. If yours is like most of the cold air kits they actually pull in hot air from under the hood. Never could figure out how they can call that a cold air intake. The stock unit draws air from behind the grill in a high pressure area, sends it through a system that flows almost 5 times the air that the engine can ever use and quiets it down nicely as well.
Oh and be advised that if that system is using an oiled gauze style filter, those like to leave oil deposits on the MAF and set off the check engine light because of the contamination of the sensor.
Nov 11, 2008 at 9:20 AM
WRW
Ok that is probably why my check engine light will come on and go off like thirty minutes later. So do you think it will be best if I put a stock unit on my car...the previous owner put the intake system on the car so i would have to buy another one. Or is there some way that i get it to stop doing that?
Nov 11, 2008 at 2:59 PM
SWILLIAMS
  • 597 POSTS
Have it scanned for the codes. That should tell you what the computer is seeing as a problem.
You should be able to find a used air intake and box easily enough. Try www.car-part.com for a local one. They are VERY easy to remove and install. That should take care of the whistle and may eliminate the CEL as well. That will depend on what is causing it.
Nov 12, 2008 at 1:54 PM
