2000 GMC Jimmy no power shakes and stalls
EMTCD
  • 2000 GMC JIMMY
  • 6 CYL
  • 4WD
  • 95,000 MILES
We just replaced the fuel pump because the truck was stalling and shuttering losing power. The problem didn't go away, we hooked it up to the computer and have gotten different codes at different times. We got multiple o2 sensor codes so my mechanich said the new fuel pump was bad, replaced that and codes went away but the trucks still no better, now the mass air flow sensor code comes up. The truck sounds like a popcorn maker and won't go over 30 mph. Initially it runs fine until the engine gets warmed up above 200 then it starts to shutter and stutter losing power. Now what? A friend told me to by pass the egr valve what else can I try?
Sunday, July 13th, 2008 AT 12:58 PM
DOCFIXIT
  • 18,828 POSTS
Post the codes you are getting it will really help.
Clean and inspect MAF clear codes run see what sets then post.
Sunday, July 13th, 2008 AT 1:20 PM
MERLIN2021
  • 17,250 POSTS
You might also want to test the ECT, when hot it should read 177 OHMS. This acts like your choke.
Sunday, July 13th, 2008 AT 3:18 PM
