2000 GMC Jimmy Hesitation
2000 GMC JIMMY
110,560 MILES • 6 CYL • 4WD • AUTOMATIC
SEACAT58
C ar hesitataes between 15 anstaysd 25mph RPM GUAGE stays at 2 Already had computer part put in and programed and new battery.
Mar 1, 2009 at 9:38 AM
Engine hesistation can be caused by the following:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Mar 1, 2009 at 9:44 AM
