2000 GMC Jimmy heater does not heat ,
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKE CRAWFORD 59
why does the heater not work , the AC is cold , the temp gauge shows 190degrees,but very little heat comes out , plus where is the radiator drain plug
Nov 28, 2008 at 3:45 PM
  • 75,988 POSTS
Check the coolant level then turn around and replace the thermostat and see what happens-lets do this simple ones 1st-before I get technical.
If its hard to find just disconnnect the bottom hose to drain the Rad-
Nov 28, 2008 at 3:51 PM
