2000 GMC Jimmy found water in fuel
144,000 MILES • 6 CYL • 4WD • AUTOMATIC
GMCSAM
I filled my gas tank right befor I got home, the next morning the truck would not start. After checking to make sure there wasn't problems with spark, I thought to change my fuel filter, and noticed the fuel that poured into a pail had water in it.
I now have the bad fuel out, and still having problems getting it to start. Could the spark plugs be gummed up with a water mixed gas?
Apr 19, 2008 at 11:21 PM
BMRFIXIT
  • 19,053 POSTS
do u have fuel pressure
i would check fuel pressure
and fuel pump
if you have spark and fuel pressure
hold the gas peddel all the way down and try to start
check also if need tune up
check FUEL PUMP
Apr 19, 2008 at 11:28 PM
