My car was not running properly so I decided to have the fuel filter changed. Before and after the change, inorder to crank the car you had to spray eyther or gas into the engine but once it started it would run until you shut the car off then it would not start again. What could be causing this and is it fixable by me or do I need to contact a mechanic?
SPONSORED LINKS
Wednesday, July 21st, 2010 AT 1:21 PM
