2000 GMC Jimmy check Engine Light soon
96,000 MILES • 4 CYL • 4WD • AUTOMATIC
ESTJAN14
My engine light comes on and then goes of with in hours or maybe the next day. I ran a dignostic test and it came back with the codes of p0101 p0174 p0171. What does that mean and I just had the fuel pump replaced last week. I have put so much money into this SUV than any other car I have owned. Its Killing me.
Oct 2, 2008 at 4:30 PM
SWILLIAMS
  • 597 POSTS
P0101 - Mass air flow sensor circuit range problem.
P0171 - System too lean Bank 1
P0174 - System too lean Bank 2
Check the Mass Air flow sensor connection and test the sensor as well. You can look at the data live if your scan tool allows it.
A bad MAF can cause all three codes.
Oct 13, 2008 at 1:29 PM
