1999 GMC Jimmy trouble starting car
MSANNIE349
  • 1999 GMC JIMMY
  • 6 CYL
  • 4WD
  • 90,000 MILES
I put a whole new fuel pump and filter on my Jimmy then I had a small gas leak.I had the leak fixed. The car always started easy now I have trouble starting it>its also sluggish going up hills.
Tuesday, August 31st, 2010 AT 8:44 AM
WRENCHTECH
  • 20,761 POSTS
The first thing you want to do is test the fuel pressure with a gauge during the failure. This vehicle requires over 55PSI at all times and unless you are using a Delco brand pump, the rest are unreliable.
Tuesday, August 31st, 2010 AT 9:13 AM
MSANNIE349
But it it started good with the new fuel pump didnt have trouble un til he pieced in the gas line that was leaking
Wednesday, September 1st, 2010 AT 8:03 AM
