1999 GMC Jimmy trans slipping
MARK1313
Transmission problem
1999 GMC Jimmy 6 cyl Four Wheel Drive Automatic
my transmission is slipping in 1st and 2nd is there a easy cheap fix
Apr 4, 2010 at 11:17 AM
MIDDY
  • 30 POSTS
Short answer, no.
Pull your tranny dipstick, see if there is any grit in the fluid on the end. Those transmissions have a sun shield that likes to blow up, requires a tranny rebuild or replacement. If your sun shield went, you'll feel grit in the fluid.
Apr 5, 2010 at 5:50 AM
