1999 GMC Jimmy radiator
1999 GMC JIMMY
113,439 MILES • 6 CYL • 4WD • AUTOMATIC
3233FR3WDCP
I have a coolient problem. the overflow resevor was dry, I filled with coolent 2 day ago and now a puddle of coolent is under the jimmy.
Jul 8, 2010 at 12:44 PM
RICHZOMBIE
  • 173 POSTS
Is it a fast leak or a slow leak? The best way to troubleshoot this is to fill the tank again and try to see where the coolant is leaking from. If you can't see the exact place where it is leaking, try to find the area where it is leaking. This way you will know if it is the water pump or a hose. You may even just have a loose hose.
Jul 8, 2010 at 1:04 PM
