1999 GMC Jimmy Grinding noise from the front tire/brake whi
1999 GMC JIMMY
112,000 MILES • 6 CYL • 2WD • AUTOMATIC
EFREN PASCASIO
I installed new brake pads but now I hear grinding noise from the front tire/or brake. Could it be that the bearings at the back of the rotor are bad?
Jul 6, 2010 at 10:42 AM
HMAC300
  • 48,601 POSTS
anytime that you do front brakes you should repack the bearings inner and outer unless it is a sealed bearing. this could be just rust making noise either rubbing on the caliper or the dust shield.. you should really check it or take it to a pro and let him check it.
Jul 11, 2010 at 8:11 AM
