1998 Jimmy with 74,000 miles
1998 GMC JIMMY
STEF1118
It just started to hesitate in the morning only. It seems as I get to work, it is running fine. I noticed that if it is raining, then it really runs bad in the AM. But like I said before, in the afternoon it runs great. Help!!!
Oct 22, 2007 at 11:16 AM
SERVICE WRITER
  • 9,123 POSTS
Cap, rotor wires may be the source. I would use a/c delco or delphi parts on this one. You may be able to reproduce the problem in the afternoon by misting water at the distributor, on the wire down to the plugs.
Oct 24, 2007 at 5:33 AM
STEF1118
You were right, it was the wires and cap. The wrong spark plugs were put in, which caused the the cap and rotor to burn. Needless to say it is costing $520 to fix. Thank you for your response!!!!
Oct 24, 2007 at 9:56 AM
SERVICE WRITER
  • 9,123 POSTS
I thought I was trying to help someone. It wouldn't have cost $520 our way.
Oct 24, 2007 at 10:19 AM
