1998 GMC Jimmy wont start say its o2 sensors
1998 GMC JIMMY
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
BROWM816748
sometimes when shut off wont start again told copukld be o2 sensors or pass lock sensors
Sep 26, 2009 at 7:29 AM
The oxygen sensor will not prevent the engine from starting. If its cranking over and refuses to start-do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Sep 26, 2009 at 7:36 AM
