1998 GMC Jimmy transmission trouble
1998 GMC JIMMY
MMA_FIGHTER06
Transmission problem
1998 GMC Jimmy 6 cyl Manual 100000 miles
my truck will not go into reverse at all and is hard to go into first i do not want to have to replace the whole transmission as money is tight is there a specific route i can try in order to avoid buying a new tranny i do not think that the oil or filter has ever been changed but i dont know if that would be good enough to fix it please help
Apr 12, 2010 at 12:28 AM
DOCFIXIT
  • 18,828 POSTS
Check hydraulic fluid in resivor if good most likely needs clutch
Apr 12, 2010 at 6:20 AM
