how can you reset the outside temperature gauge? My gauges seems to be reading about 40 degrees high.
Jun 24, 2009 at 2:56 AM
SWILLIAMS
✓Experienced Mechanic
It is self calibrating. If it always reads wrong the sensor has probably failed. There is a test procedure but you need the factory book to get it.
Jun 24, 2009 at 4:22 PM
LMAC
MEMBER
Generally whats involved to replace the gauge and whats the cost?
Just trying to see if its worth the exopense.
thanks for your input.
Jul 1, 2009 at 3:16 AM
SWILLIAMS
The sensor is a simple plug in part located behind the grill . The wiring runs just under the upper edge of the radiator support and across to the sensor.
Jul 2, 2009 at 2:30 AM
LMAC
MEMBER
[quote:6cfee7f336="SWilliams"]The sensor is a simple plug in part located behind the grill . The wiring runs just under the upper edge of the radiator support and across to the sensor.[/quote:6cfee7f336]
