1998 GMC Jimmy miss
1998 GMC JIMMY
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
GRAHAM1
I have changed plugs and wires distributor cap and button, checked compression on number 1 it is 115lbs, but I still have a miss on number 1 cylinder what should I do next, all other cylinders do not show a miss on snap-on computer. just number 1 cylinder. have checked wires by moving them around to differ position still on number one
Aug 31, 2010 at 3:08 PM
MADMIKE1735
  • 951 POSTS
while its running, pull off the wire for cyl 1... if you dont know any difference in engine performance then check that you have contact on that wire... you may need to push some wire into the boot... it may also be a fuel injector...
Aug 31, 2010 at 3:13 PM
